AlexFujita
#1 Posted : Thursday, May 18, 2017 11:44:43 PM(UTC)
AlexFujita
Hi, I'm using SFX to create graphical presentation of my product.
I've been using "Subtract Solid" tool to make cross section view.
Now I noticed there was other way to do, "Clipping Plane?", but I can not find how to execute.
Can some one teach me how to use it?
Thank you
AlexFujita attached the following image(s):
Cross Section.jpg (32kb) downloaded 12 time(s).
L. Banasky
#2 Posted : Friday, May 19, 2017 3:40:55 AM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
Hi Alex,
Hope this helps.
http://www.screencast.com/t/foC0jS9uXI
thanks 2 users thanked L. Banasky for this useful post.
AlexFujita on 5/19/2017(UTC), MaiFy on 5/19/2017(UTC)
AlexFujita
#3 Posted : Friday, May 19, 2017 9:05:31 AM(UTC)
AlexFujita
Hi Larry,
Thank you for the tips.
I still have some display bug on cut area of the solid, but I would try some way to workaround.
Alex
horst.w
#4 Posted : Friday, May 19, 2017 11:49:13 AM(UTC)
horst.w
If you divide the object with the Split Solid tool (instead the Trim Tool) by using 2 levels of Infinite Plane, you get 4 parts. One or two parts put to different layers, then you can hide them in the Concept Explorer as ever you want. To get a realistic cross view like your example you can add once more again two or tree parts with Add Solids.
horst.w, GER
Edited by user Friday, May 19, 2017 2:37:26 PM(UTC)  | Reason: Not specified
murray
#5 Posted : Sunday, May 21, 2017 7:42:07 PM(UTC)
murray
Bear in mind that clipping planes or the compound slicing that Horst proposes are limited to planar cuts. Subtraction lets you make more intricate 3D cutaways that expose features that clipping planes and slicing remove. You can make multiple subtractions to display complex features, suppress and unsuppress them as needed in concept explorer.
Edited by user Sunday, May 21, 2017 8:41:34 PM(UTC)  | Reason: Not specified
