Andrew Gray
#1 Posted : Tuesday, May 16, 2017 4:41:32 AM(UTC)
Andrew Gray
hi all
see attached screenshots - im using polylines in a sheet view
as you can see the curves have small dots, is there a way to control the dots so not to show ?
Andrew
Andrew Gray attached the following image(s):
MaiFy
#2 Posted : Tuesday, May 16, 2017 5:05:43 AM(UTC)
MaiFy
Hi Andrew
Try this.
select all
Top menu
edit
untick show points or Ctl D
Edited by user Tuesday, May 16, 2017 5:54:38 AM(UTC)  | Reason: left out edit
Andrew Gray
#3 Posted : Tuesday, May 16, 2017 6:05:38 AM(UTC)
Andrew Gray
Thanks but it didn't work
Andrew
#4 Posted : Tuesday, May 16, 2017 8:23:56 AM(UTC)
Please go first in the view frame with a mouse click and after it activated you can select the area.
Andrew Gray
#5 Posted : Tuesday, May 16, 2017 3:07:52 PM(UTC)
Andrew Gray
That worked
Guest (5)
