right click Popup shortcut
Where is the right click popup in shortcuts on SharkCad 10?
Originally Posted by: John Carter Where is the right click popup in shortcuts on SharkCad 10?
In the File : Short Cuts dialog.
(133kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
How come there is no assign to pop-up, right click. The cheaper version of ViaCad Pro 10 has it, at least in your video. Will if come to SharkCad 10?
Originally Posted by: Guest How come there is no assign to pop-up, right click. The cheaper version of ViaCad Pro 10 has it, at least in your video. Will if come to SharkCad 10?
It is in all versions, its called "Assign To Mouse"
Please post a screen shot of your file shortcuts menu.
