Hi All
see attached, I'm trying to use the pipe tool t0 draw a steel section along a line
the line is 2deg rotated, is it poss to rotate the axis so the steel section is at 2deg?
Thanks Andrew
Andrew Gray attached the following image(s):
(59kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 55 times Was thanked: 46 time(s) in 32 post(s)
Hi Andrew
Is this what you are trying to do, or something else?
(53kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Yes I can simply use the gripper and rotate 2deg but I was using the pipe tool. I tried to get the section rotated within the command
The pipe tool ask for a path curve. That may be also a straight line which is turned for x degrees.
Hope that is what you mean.
horst.w, GER
(28kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Basically want to put the square section along the line but rotate it 2 degrees
... for this I don't see a solution with the pipe tool but you can reach it with the One Rail Sweep Solid. While the rotated square pipe must be hollowed I think it is much more complex than to use the gripper.
(69kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
