mmenkeMTD
#1 Posted : Friday, May 12, 2017 8:45:51 AM(UTC)
mmenkeMTD
Having trouble with Shark FX 9 keeping properties saved. This was never a problem for me before. I knew to save the settings while a tool was not selected. This does not seem to work. I've created new custom standards or changed standard from the Value tab, but they never seem to hold/stay. When i open old files, dimension font and size change. Example in the screen shot: Default shows Arial, newly placed dimension is created in Arabic
https://www.dropbox.com/...youapv5lp/image.pdf?dl=0
In the old days there seemed like there used to be a Preferences file where you controlled defaults. If this is still the standard, its not obvious where such a file is stored. Nothing seems to be jumping out at me as "Ah Ha" from the user guide.
image.pdf (19kb) downloaded 13 time(s).
