I have a solid that I resized by selecting and dragging one end of the original profile. Unfortunately there were several bosses that ended up being moved with the update. Is there a way to easily preposition them without deleting and recreating?
HP Z800 Dual Xeon 5690 3.46Ghz 64GB nVidia Quadro 6000 6GB Win pro 7-64 SharkCAD Pro v10.0.0 B1354 Shark FX v9.0.4 B1162
Thanks: 172 times Was thanked: 157 time(s) in 107 post(s)
If you know the X,Y,Z position, you can Right click-Move Feature
and enter a new location in the Data Entry Boxes.
(78kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
Thanks Lawrence, I didn't even know that was there. Once I right click on the boss in the feature tree and select "Move Feature" I can edit the coordinates like you said or as I found out simply click the new location. Thanks again!
