Transferring license from dead computer to new computer process?
Hi Tim, How do I transfer Shark FX 9 license from a Macbook pro that ceased to function today to a new 2015 Macbook pro? I think I can access the SSD's on the old Macbook Pro, in recovery mode they are visible but the startup process stalls at about 35% which means there is an diagnostic failure. So, it is time to transfer/migrate the old to the new. Do I just install SharkFX v9 and then get the registration info from you, or tech support? I noticed that Shark Pro is now available. I might just upgrade. Would that be the easiest method? What information is needed to begin? Thanks in advance! Tem
Hi Tem Install on the new machine and re-register the v9 product. If you don't have the FX V9 installer private email me for one. >>I noticed that Shark Pro is now available. I might just upgrade. If you have PowerPack Pro, be sure to purchase from EvoSoft and not Encore. PowerPack Pro is only available from EvoSoft. Tim
Thanks: 6 times Was thanked: 11 time(s) in 10 post(s)
Hi Tim I have the same problem I assumed I purchased power pack pro please could you help. I installed a few days ago and did not realise Regards Brian Sayer
