Suggestions
Automatic focus the main-window when mouse out of the child-window
Thanks: 264 times Was thanked: 131 time(s) in 101 post(s)
When using the concepts explorer or the select mask or inspector and want going back to the main window to work on the construction is always a mouse click needed for making the main window active. When mouse out of this windows should this windows be no longer active and also should then the 3dconnexion work again.
Suggestions
