Suggestions
Keyboard-Shortcut for Zoom Out Minus (-) are not good
I removed several times the Keyboard-Shortcut for Zoom Out, the Minus (-). The Minus is needed for typing values while making a construction. Please use another Key for this, not the Minus and maybe also not the Plus. Maybe E and D or something else. I dont need this, maybe remove it completely.
Edited by user Wednesday, May 9, 2018 11:19:34 AM(UTC)
Why do we need 3 different shortcut Keys for Zoom in and Zoom Out? I deleted the entries from the config file. This was not a good idea, because Shark create it again with the + and -. Only when 3 different keys assigned do shark no longer recreating the Minus-Key.
The + and - Keys for Zoom are imo. completely useless. I hope the automatic creating of this
Code: View:Zoom In=' ] ! View:Zoom Out=[ ? #
Config entries will be removed soon. For zoom are the In-Stream Zoom Commands enough, and the mouse wheel can be used by new users.
Suggestions
