New Topic Post Reply
zircon
#1 Posted : Wednesday, April 19, 2017 7:41:17 AM(UTC)
Quote
zircon
Japan
This is 100% repeatable on my system.
Procedure:
Open attached file to see what it looks like:
View-Isometric
w
Now see what it looks like referenced:
Open Shark FX
n
File-Reference-Attach
(Select file attached to this message)
View-Isometric
w
MacBook Air (13-inch, Mid 2013)
1.7 GHz Intel Core i7
8 GB 1600 MHz DDR3
OSX 10.11.6(Japanese)
Shark FX v9.0.13 (1224)
Edited by user Wednesday, April 19, 2017 7:43:31 AM(UTC)  | Reason: Word missing in description
2f framing top.sfx (1,350kb) downloaded 14 time(s).
8 GB 1600 MHz DDR3
SharkCad Pro v10.0.0 (1335)
#2 Posted : Wednesday, April 19, 2017 9:43:10 AM(UTC)
Quote
Was thanked: 11 time(s) in 10 post(s)
Hello Zircon,
I confirm reference does nothing with V9 b1224.
With V10 b1337 it is even worse (see my screen grab)...
Polygons seems to stretch to long distance...
L. Banasky
#3 Posted : Wednesday, April 19, 2017 10:00:06 AM(UTC)
Quote
L. Banasky
Was thanked: 32 time(s) in 28 post(s)
Hi Zircon,
Could be a Mac issue, seems to work on Windows.
zircon
#4 Posted : Thursday, April 20, 2017 2:51:28 AM(UTC)
Quote
zircon
Japan
Jim,
Thanks for the confirmation. My issue is that items deleted from a file appear when it is used as a reference file. Did you also originally have some polygons in the referenced file that were deleted?
Larry,
This is most interesting. So in Windows the file looks exactly the same whether you open the file to edit or specify it as a reference for another file? I can't see the solids when I open the file to edit it. (Again, they did exist earlier but I deleted them after they'd served their purpose.) Are you also able to manipulate the solids?
8 GB 1600 MHz DDR3
L. Banasky
#5 Posted : Thursday, April 20, 2017 3:10:20 AM(UTC)
Quote
L. Banasky
Hi Zircon,
The 2 .jpgs only show the reference and attach, one is Shark9 and the other is Shark10.
If you open to edit, all you see are the rectangles and square outlines, no solids.
I cannot edit reference attach file.
horst.w
#6 Posted : Thursday, April 20, 2017 4:07:58 AM(UTC)
Quote
horst.w
I tried it to open in ViaCAD 10 and also couldn't see a solid, only some edgepoints (?).
But after trying to convert it to a solid there is the message "nothing to convert" and the Top-View - a little bit set angular - shows this here:
ViaCAD 9 Pro german + ViaCAD 10 Pro & PowerPack
zircon
#7 Posted : Thursday, April 20, 2017 8:20:00 AM(UTC)
Quote
zircon
Japan
Thanks, everyone.
Yes—the problem is that the solids seen when the file is referenced should not exist. They were all deleted at an earlier stage.
When I open the file to edit it, they do not exist. However, they do show up when the file is referenced.
I should have attached screenshots to my first post. I've done so now.
The first one is of the file as it looks like when opened to edit, and the way I expect it to look when referenced. It contains no solids.
The second one is the same file when referenced from a new empty file.
If anyone can help me figure out what I'm doing wrong or what's happening I'd be most grateful.
I do notice that the "Reference" layer of the file attached to my first post contains 912 objects. It should only contain one—the vertical levels. Thus, I believe that the solids must be hiding in that layer. However, I can't find them. Perhaps if I delete that layer I can get rid of them. And yes, they did disappear once the layer was deleted.
I'd still like to know what would make this happen.
Edited by user Thursday, April 20, 2017 8:29:55 AM(UTC)  | Reason: Not specified
zircon attached the following image(s):
8 GB 1600 MHz DDR3
daleroe
#8 Posted : Tuesday, May 09, 2017 2:36:25 PM(UTC)
Quote
daleroe
I have this problem also. It is incredibly frustrating! I attached a part and then edited the part by simply turning on some layers and updated the reference. That's when all these anomalies showed up. The sweep lines appeared along with several copies of a fuse holder that I only attached once but ended up moving around several times. I hide the sweep lines in the part but they still show up with the referenced part. The additional fuse holders are not in the part, only the referenced part.
daleroe attached the following image(s):
HP Z800 Dual Xeon 5690 3.46Ghz 64GB
nVidia Quadro 6000 6GB
Win pro 7-64
Shark FX v9.0.4 Build 1162
Quick Reply Show Quick Reply
Guest (13)
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
