Sam T
#1 Posted : Tuesday, April 11, 2017 9:51:48 PM(UTC)
Question: Suppose I am doing mulitple cutsheets for a customer in one of my drawings, and I want to put the customers name in the title block. How would I do this? Do I go to the template file that the model to sheet tool pulls from and put the customer's name into the template file or obviously I could manually type in the customers name on each and every cutsheet, or is there an easier way? I am using ViaCAD 2d/3d v9.
Sam
#2 Posted : Wednesday, April 12, 2017 4:42:18 AM(UTC)
Was thanked: 67 time(s) in 65 post(s)
Sam
Create one sheet template and save it as a symbol and you can pull it in as many times as needed. Or create a custom model to sheet template and use that when generating the model to sheet.
Windows 10, Win 7
#3 Posted : Wednesday, April 12, 2017 2:36:23 PM(UTC)
Was thanked: 191 time(s) in 168 post(s)
In addition to Jason's suggestions you can use the File : Properties command to set:
Title
Subject
Company
The template will then autofill the following text fields
<Company> =Company
<Project> = Title
<Description> = Subject
ViaCAD/Shark Development Team
Links to ViaCAD Resources
Sam T
#4 Posted : Thursday, April 13, 2017 8:27:49 PM(UTC)
That's great!
Appreciate it!
