#1 Posted : Monday, April 10, 2017 12:57:07 PM(UTC)
Please make it possible to copy "Verify Length" to clipboard or do the length copyable to the inspector like it is realized in draftboard.
#2 Posted : Monday, April 10, 2017 1:04:53 PM(UTC)
Was thanked: 189 time(s) in 167 post(s)
>copy "Verify Length" to clipboard or do the length copyable to the inspector like it is realized in draft board
Although not the Verify Length dialog box, you can in the later V10 builds copy to the clipboard the values displayed when you right click on an object. Attached is a new tip from the V10 Tips and Tricks book (work in progress:).
I have been using this feature quite a bit. However, be sure to set your units to display the appropriate amount of decimal digits.
Edited by user Monday, April 10, 2017 1:10:05 PM(UTC)  | Reason: Not specified
ViaCAD/Shark Development Team
Links to ViaCAD Resources
#3 Posted : Wednesday, April 12, 2017 10:36:41 AM(UTC)
Was thanked: 9 time(s) in 8 post(s)
ok, the context menu is a little bit overloaded and please remove the unit. I need only the digits and not the unit like mm for millimeter. The best solution will be putting the length of a curve to the inspector or also the best will be to make all verified values copyable.
If textify not only available in 32 bit, is this no longer my problem :)
Edited by user Wednesday, April 12, 2017 10:53:36 AM(UTC)  | Reason: Not specified
