Punch Lounge
manipulating the title block
Question: Suppose I am doing mulitple cutsheets for a customer in one of my drawings, and I want to put the customers name in the title block. How would I do this? Do I go to the template file that the model to sheet tool pulls from and put the customer's name into the template file or obviously I could manually type in the customers name on each and every cutsheet, or is there an easier way? I am using ViaCAD 2d/3d v9. Thanks, Sam
Sam Create one sheet template and save it as a symbol and you can pull it in as many times as needed. Or create a custom model to sheet template and use that when generating the model to sheet. Regards Jason
In addition to Jason's suggestions you can use the File : Properties command to set: Title Subject Company The template will then autofill the following text fields <Company> =Company <Project> = Title <Description> = Subject Tim
That's great! Appreciate it!
Thanks: 123 times Was thanked: 32 time(s) in 20 post(s)
It is my hope that <Author> and <Manager > will also be extracted from the File:Properties in a future ViaCAD/SharkCAD version (if this is possible?) kind regards Danny
BR Danny Windows 10 Pro, SharkCAD v14 Pro (1653), XPS 15,9980HK Sonoma 14.3, SharkCAD v14 Pro (1653), MacBook Pro 14 2023,M3
Punch Lounge
