Sam T
#1 Posted : Tuesday, April 11, 2017 9:51:48 PM(UTC)
Question: Suppose I am doing mulitple cutsheets for a customer in one of my drawings, and I want to put the customers name in the title block. How would I do this? Do I go to the template file that the model to sheet tool pulls from and put the customer's name into the template file or obviously I could manually type in the customers name on each and every cutsheet, or is there an easier way? I am using ViaCAD 2d/3d v9.
Sam
#2 Posted : Wednesday, April 12, 2017 4:42:18 AM(UTC)
Sam
Create one sheet template and save it as a symbol and you can pull it in as many times as needed. Or create a custom model to sheet template and use that when generating the model to sheet.
#3 Posted : Wednesday, April 12, 2017 2:36:23 PM(UTC)
In addition to Jason's suggestions you can use the File : Properties command to set:
Title
Subject
Company
The template will then autofill the following text fields
<Company> =Company
<Project> = Title
<Description> = Subject
Sam T
#4 Posted : Thursday, April 13, 2017 8:27:49 PM(UTC)
That's great!
Appreciate it!
damhave
#5 Posted : Wednesday, August 9, 2023 10:57:22 AM(UTC)
damhave
Denmark
It is my hope that <Author> and <Manager > will also be extracted from the File:Properties in a future ViaCAD/SharkCAD version (if this is possible?)
kind regards
Danny
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
SharkCAD v14 Pro(1653),
MacBook Pro 14 2023,M3
