Import/Export
Problem importing Rhino 3Ds and exporting ti FACT
Was thanked: 3 time(s) in 1 post(s)
Hi all, is there an option or possibility to import a 3Ds file and export it to FACT with preserving the original hierarchy? In the concepts explorer the structure seems to be ok except the sublayers, but I couldn't find a solution to preserve the hierarchy also in a FACT file or any other. Many thanks for helping Frank
Was thanked: 519 time(s) in 357 post(s)
Hi Frank >> with preserving the original hierarchy? Just to clarify, the sub layers or grouping? Tim
Hi Tim,
the layer, sublayer structure shows up in Concept Explorer, but is not preserved by exporting into FACT file format.
This would be extremely helpful for mechanical visualisation with thousands of parts which are stored in different layers.
Best regards
Frank
Originally Posted by: Tim Olson Hi Frank >> with preserving the original hierarchy? Just to clarify, the sub layers or grouping? Tim
(859kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
Hi Tim, I attached a screenshot, which hierarchie should be preserved in the export. Best regards Frank
Import/Export
