New Topic Post Reply
24c
#1 Posted : Sunday, April 09, 2017 8:40:20 AM(UTC)
Quote
24c
Hi Tim,
Just a quick one, when using the Push/Pull tool in MacOS SharkCAD Pro build 1335, the default tab entry is the X field, not the distance one.
It used to be the distance moved input box one as far as I remember.
Cheers
Mike
#2 Posted : Monday, April 10, 2017 12:18:28 PM(UTC)
Quote
Was thanked: 160 time(s) in 141 post(s)
Thanks Mike for the heads up, this is updated in the 1338+ builds to default to distance.
ViaCAD/Shark Development Team
EvoSoft
Links to ViaCAD Resources
Quick Reply Show Quick Reply
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
