Suggestions
Shark slows the starting of the UI of other programs extremely down
Thanks: 265 times Was thanked: 131 time(s) in 101 post(s)
The following programs have problems with the starting of a new UI after some works with Shark CAD: Excel, Beyond Compare and MultiCommander. Maybe there are more programs, but i found at time only this three.
Hello This is an os function launching multiple programs. What os are you using? Regards Jason
Hello, i use Windows 10 64 bit 1703, and in 1607 was the problem maybe a little bit bigger.
Suggestions
