3dup
#1 Posted : Friday, April 7, 2017 8:52:53 AM(UTC)
3dup
Was thanked: 5 time(s) in 3 post(s)
I have some old VCP files made some years ago. Now I want to slice the STL in S3D for 3D_printing, and getting a "self intersecting surfaces" warning?
Is there a way to find and correct/repair that in VCP V10? Or maybe with the V10 PowerPack, before i exporting to STL?
#2 Posted : Friday, April 7, 2017 11:20:51 AM(UTC)
You can see if Verify: Check Object will pick it up.
Visually you can try the 3D Print Tools : Slices command. If you have a loop in the 2D slice you might have a self intersection in the 3D model.
