azbi
#1 Posted : Thursday, April 06, 2017 10:56:22 AM(UTC)
azbi
Hello
I have set the Custom Resolution in Preferences to Super Fine, and even changed Curve and Angle to 1.0 each. I work in ViaCAD Pro 10.
I draw a doughnut (two rings, Push/Pull, or Extrude Solid and subtract the inner - I tired both). There are facets. Why? (see pic 1)
However, when I export my doughnut to .dxf it mutates to an angular object with 18 facets. (see pic 2)
What am I doing wrong - or rather: how can I get a better resolution?
TIA
andy
PS: When I subtract a free form from the ring things get weirder, but one thing at a time.
Edited by user Thursday, April 06, 2017 11:09:37 AM(UTC)  | Reason: Not specified
azbi attached the following image(s):
#2 Posted : Thursday, April 06, 2017 11:10:32 AM(UTC)
Was thanked: 78 time(s) in 75 post(s)
Originally Posted by: azbi Go to Quoted Post
Hello
I have set the Custom Resolution in Preferences to Super Fine, and even changed Curve and Angle to 1.0 each. Which looks all fine when inspecting in ViaCAD Pro 10.
TIA
andy
Hello Andy
What program are you opening the dxf in?
Can you post the files? You can zip the dxf to post it.
Windows 10, Win 7
#3 Posted : Thursday, April 06, 2017 11:46:37 AM(UTC)
Andy
The first picture is the visual or screen view of the object.
What program is the second pic opened in? The dxf I re-imported into ViaCAD looks fine here.
Windows 10, Win 7
posh.de
#4 Posted : Friday, April 07, 2017 4:12:02 AM(UTC)
posh.de
Was thanked: 26 time(s) in 21 post(s)
don't evaluate objects by a screen resolution possibly reduced for display output speed as e.g. in ACAD (REGEN command helps) but select the entity and check object type etc. in the element property dialogue of the used application.
For evaluating entities from DWG/DXF files you can do this with the free Teigha Viewer.
POSH GmbH
www.posh.de
