New Topic Post Reply
#1 Posted : Tuesday, March 28, 2017 9:30:15 AM(UTC)
Quote
Was thanked: 11 time(s) in 10 post(s)
Hello,
I know the stl format isn't clear with units, but...
With Shark in mm :
If I export a solid and re-import it straight afterward...it is 24.5 times bigger.
Good growth !
Trump effect ?
#2 Posted : Tuesday, March 28, 2017 12:51:35 PM(UTC)
Quote
Was thanked: 160 time(s) in 141 post(s)
There is a unit drop down now in v10 in the export dialog. it seems most slicer apps want MM even if you are working in inches.
ViaCAD/Shark Development Team
EvoSoft
Links to ViaCAD Resources
#3 Posted : Tuesday, March 28, 2017 1:42:29 PM(UTC)
Quote
Yes Tim, this drop down is set to "mm"
So it seems to export mm OK...
But when I reimport the same file---> each mm is measuring 1 inch (even with import drop down in mm)
Seems to be a small bug...
#4 Posted : Tuesday, March 28, 2017 1:51:44 PM(UTC)
Quote
Thanks for the heads up...checking...
EvoSoft
24c
#5 Posted : Tuesday, April 04, 2017 1:42:56 PM(UTC)
Quote
24c
Tim,
Just for the record, I got the same issue. A previous exported .stl file saved in mm, was dropped into ShardCAD Pro macOS 1335, and when exported again in mm, was too big for the build volume of my 3D printer.
A quick check with a circle tool, told me it was imported as inches, not mm(the original file is in mm in the printer import). I tried scaling by 1/25.4, but I was getting an origin shift in the slicer programme (Automaker a form of Cura), but I don't think this is one of yours. :)
Cheers too jlm for the feedback on .stl files
Mike
#6 Posted : Tuesday, April 04, 2017 4:01:15 PM(UTC)
Quote
Drats, I have not been able to get this to repeat yet. I have tried exporting as MM and importing as MM. Both Import and Export now have a drop down specifying units.
EvoSoft
24c
#7 Posted : Tuesday, April 04, 2017 4:16:39 PM(UTC)
Quote
24c
Tim,
I know what I did now, and why you're not getting a repeat.
I dragged the stl file from my desktop and dropped it on a new SharkCAD Pro drawing (as in a blank page), so I didn't go through the Import dialog box and select mm.
That's all it is. If I do an import, no issue, but my dimensionally sound (mm) stl file dropped onto SharkCAd converts to inches by default, as I've just checked some known good files with the circle tool and noting the diameter.
Hope this helps, but not sure what you can do about it.
Mike
#8 Posted : Tuesday, April 04, 2017 5:00:24 PM(UTC)
Quote
Mike
Awesome..checking!
EvoSoft
#9 Posted : Wednesday, April 05, 2017 12:58:24 PM(UTC)
Quote
This is now fixed the 1337+ builds.
EvoSoft
24c on 4/5/2017(UTC)
Quick Reply Show Quick Reply
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
