New Topic Post Reply
24c
#1 Posted : Monday, April 03, 2017 1:25:01 PM(UTC)
Quote
24c
Hi
Silly question, but I'm playing with dual material printing with my 3D printer, and hen I save the SharkCAD Pro model, I get default facets or triangulations, that can be seen in the 3D print model, and the print.
This is a snapshot of the "Automaker" slicer software representing the parent material (blue) and the support material (orange), and the actual 3D print in "normal" mode.
Has anybody else experimented with the default STL export settings to reduce this "facetting" or triangulation with their 3D printer.
Many thanks
Mike
murray
#2 Posted : Monday, April 03, 2017 5:41:09 PM(UTC)
Quote
murray
Was thanked: 10 time(s) in 10 post(s)
Right-click on your (native nurbs) model in VC and select change object type, choose mesh. The dialogue panel opens as shown, the mesh parameters change the .stl facet resolution. Cancel the change type instruction so that your model remains fully editable and associated, keep it selected and export the selection only as .stl, the .stl will retain the facet resolution that you've specified. If you've saved your model as .stl without retaining the native VC nurbs original, you've lost the capacity to do this and it'll have to be rebuilt to recover it.
Edited by user Monday, April 03, 2017 5:41:53 PM(UTC)  | Reason: attachment
mesh parameters.png (448kb) downloaded 11 time(s).
24c
#3 Posted : Tuesday, April 04, 2017 12:54:51 AM(UTC)
Quote
24c
Thanks for that murray,
Last night after posting the question, I did just change the STL Mesh Parameters Normal Deviation from the default 8.0 to 2.0, and I got a similar effect to your image.
I will try your method, but just a FYI, I already see improved aka finer "facetting" on the 3D print model.
Mike
#4 Posted : Tuesday, April 04, 2017 4:21:04 AM(UTC)
Quote
Was thanked: 11 time(s) in 10 post(s)
Adjusting the parameters is a bit tricky.
I always do small and accurate parts in HD sla.
Here are my usual parameters...
Capture d’écran 2017-04-04 à 11.15.31.png (1,099kb) downloaded 15 time(s).
Quick Reply Show Quick Reply
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
