Andrew Gray
#1 Posted : Friday, March 17, 2017 12:11:17 AM(UTC)
Andrew Gray
hi all
attached is a sample file, not sure if this is a bug
or some thing I am doing wrong
i have a simple rectangle push-pulled up with a hole thru
i mirror the part and make a 2d sheet
the problem is a cant seem to add a centerline to the mirrored part (left hand side)
if I do add, the centerline goes to the right hand part
same problem if i copy the part over
see attached sample
Andrew
EDIT: same issue with sections? can't add centerlines to circles
what is happening is the centerline is going on to the parent view
Edited by user Friday, March 17, 2017 1:55:31 AM(UTC)  | Reason: Not specified
HOLE TEST.vc3 (71kb) downloaded 10 time(s).
Andrew Gray attached the following image(s):
#2 Posted : Sunday, March 19, 2017 1:39:26 PM(UTC)
Thanks Andrew for the heads up, this is now fixed in 1333+ builds.
I have not checked the section issue yet.
Andrew Gray
#3 Posted : Sunday, March 19, 2017 2:26:45 PM(UTC)
Andrew Gray
would you have a rough time line for the release of the new version?
Andrew
Andrew Gray
#4 Posted : Wednesday, March 29, 2017 4:10:06 AM(UTC)
Andrew Gray
Hello
how can i get the latest version (build) to fix some issues
I still have 1318 VC10
Thanks Andrew
Andrew Gray
#5 Posted : Friday, April 7, 2017 2:54:33 PM(UTC)
Andrew Gray
Hi Tim
When do you estimate the new version will be out
Otherwise I will need to export to AutoCAD to finish the project and get paid
I put in a support ticket but didn't get a response back
Thanks Andrew
HIolemis1
#6 Posted : Friday, May 26, 2017 3:59:30 AM(UTC)
HIolemis1
You did a good job.
Andrew Gray
#7 Posted : Friday, May 26, 2017 4:36:52 AM(UTC)
Andrew Gray
Hi
I still waiting for the bug fix
BTW no response from support either
Andrew
