center line issue with mirrored/copy parts
hi all
attached is a sample file, not sure if this is a bug
or some thing I am doing wrong
i have a simple rectangle push-pulled up with a hole thru
i mirror the part and make a 2d sheet
the problem is a cant seem to add a centerline to the mirrored part (left hand side)
if I do add, the centerline goes to the right hand part
same problem if i copy the part over
see attached sample
Andrew
EDIT: same issue with sections? can't add centerlines to circles
what is happening is the centerline is going on to the parent view
Edited by user Friday, March 17, 2017 1:55:31 AM(UTC)
HOLE TEST.vc3
(71kb) downloaded 10 time(s). Andrew Gray attached the following image(s):
(35kb) downloaded 19 time(s). You cannot view/download attachments. Try to login or register.
>>the problem is a cant seem to add a centerline to the mirrored part (left hand side) >>if I do add, the centerline goes to the right hand part >>same problem if i copy the part over Thanks Andrew for the heads up, this is now fixed in 1333+ builds. I have not checked the section issue yet. Tim
Tim would you have a rough time line for the release of the new version? Andrew
Hello how can i get the latest version (build) to fix some issues I still have 1318 VC10 Thanks Andrew
Hi Tim When do you estimate the new version will be out Otherwise I will need to export to AutoCAD to finish the project and get paid I put in a support ticket but didn't get a response back Thanks Andrew
Hi I still waiting for the bug fix BTW no response from support either Andrew
