New Topic Post Reply
#1 Posted : Saturday, August 16, 2014 1:37:53 PM(UTC)
Quote
For hull fairing and other similarities, I think SLT/VCP don't have quite this equivalent, at the 00:30 index:
http://www.youtube.com/watch?v=...ure=youtube_gdata_player
I sometimes find that the only way to make a surface track/match a curve is to add more stations, but that gradually degrades fairing and creates more work to battle "unfiaring" when even just one curve is adjusted downstream in the workflow in the region.
An alternative would be if I could make a point some have the quality/attribute of a "corner point" so that creases could be imposed just locally. But, for that I add more "control curves" to force manipulation locally.
Overall, I've gotten so much of what I wanted, but it took a long amount of work. If I hand off that process to others, they might question my sanity or perseverence, hehehehe...
#2 Posted : Saturday, March 18, 2017 8:50:20 AM(UTC)
Attach Quote
Appoacietirn for this information is over 9000-thank you!
Quick Reply Show Quick Reply
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
