Andrew Gray
#1 Posted : Thursday, March 16, 2017 4:16:22 AM(UTC)
Andrew Gray
Hi all
more questions
I am having troubles working out about adding dims and notes to a 2d drawing
if I DONT click into a 2d drawing frame (eg red dashed line don't visible), add a dim or note, I can't seem to edit the dim because the frame is bring selected first and I can't select (get to) the dim
but if I select the drawing frame first (eg the red dashed line is visible) then place a dim, I can select it and edit it
is this just the way it is?
Andrew
Andrew Gray attached the following image(s):
#2 Posted : Thursday, March 16, 2017 12:16:10 PM(UTC)
HI Andrew
Yes, you will need to activate the draw view to add dimensions to objects in the draw view.
Draw views are "activated" because they contain a different view orientation and scale than the sheet they are in.
There is an option to flatten a draw view. This will remove the draw view by projecting and scaling the contents into the current sheet view.
Andrew Gray on 3/16/2017(UTC)
