Hi, When I create a "diagonal polygon" (rectangle or square), I am not able to fillet the lines using the fillet tool. If I simply create two lines, I am able to use the fillet tool. Any ideas why this is not working properly? I just upgraded from ViaCAD Pro V6 to V10. Thank you
Try using the Single Line option instead of Smart Polygon. A Smart Polygon cannot be modified except by the parameter definitions. We need to add a prompt to the user when they try this on a polygon.
Edited by user Tuesday, March 7, 2017 5:17:06 PM(UTC)
