John C H
#1 Posted : Monday, January 30, 2017 12:02:44 PM(UTC)
John C H
ViaCAD 2D/3D v10 on Mac El Capitan.
When I switch to Wire frame mode, following how to build a cup video, my background is white and the wire frame lines are white. How do I change the wire frame colors so I can see them against a white background?
John C H
Canada
#2 Posted : Monday, January 30, 2017 1:36:48 PM(UTC)
Hi John
Try setting Preferences: Display: Surface: Edge color.
defkon
#3 Posted : Tuesday, March 7, 2017 12:24:08 PM(UTC)
defkon
Hi Tim
the same here but at me there are no options for changing color.
All in red are blank in my preferences, the last i can see is Resolution
and the next is Pen weights.
Any idea?
Matthias
defkon attached the following image(s):
#4 Posted : Tuesday, March 7, 2017 12:49:59 PM(UTC)
Is it possible your Object Type is set to Curve? Curves do not have these settings as an option.
defkon
#5 Posted : Tuesday, March 7, 2017 1:58:17 PM(UTC)
defkon
Yes, this was the solution
Many Thanks
Matthias
