defkon
#1 Posted : Monday, March 6, 2017 1:26:42 PM(UTC)
defkon
I have a question about memory management of ViaCad in Mac OS, i used 10.11.6.
I often open several files at the same time in VC and i can see in the activity monitor the memory requirement of VC increases.
Sometimes it increases up to 10 GB and then the > memory pressure <is to hard and nothing works.
Clothing windows don't decrease the memory requirement.
Only Quit the app is the solution.
Is this behavior normal
Thanks Matthias
defkon attached the following image(s):
Memory use.png (47kb) downloaded 10 time(s).
#2 Posted : Monday, March 6, 2017 4:15:06 PM(UTC)
I will need to check into restarting ACIS when all windows are closed. ACIS has its own memory manager that only frees when ACIS is closed down.
