jbskaggs
#1 Posted : Thursday, February 23, 2017 12:45:43 PM(UTC)
jbskaggs
I have two objects 1.5x3.5x22.5 that intersect, so I use the subtract option. The new object after the material is removed is now 1.5x2.0x22.5 but the inspector stills shows it as 1.5x3.5x22.5. Is this an error? This is the yellow part.
Edited by user Thursday, February 23, 2017 1:14:01 PM(UTC)  | Reason: Not specified
jbskaggs attached the following image(s):
twin over full bed ends2.jpg (86kb) downloaded 7 time(s).
#2 Posted : Thursday, February 23, 2017 1:42:46 PM(UTC)
>>Is this an error?
No, appears to be correct.
The data entry window & inspector look through the history tree and see what operation made the selected face and display those attributes.
if you change one of these parameters the block will update as well as dependent children such as the boolean operation.
