Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
There seems to be a character limit in a text box no matter how large I make it. Is it possible to change the limit?
Originally Posted by: Dyn_Metalworks There seems to be a character limit in a text box no matter how large I make it. Is it possible to change the limit?
Hello
How many characters have you tried I have 10,000 and it looks like that is max.
Not near 10,000. I have around 3,000. It just stops typing. If I copy/paste from Word it only pastes part of it.
Anyone else have suggestions? In a pinch trying to get a project done.
Can you just use multiple boxes ? Regards Jason
I tried that, but when I print the text moves up.
Windows was set at 10K, Mac at ~2048. I've updated the Mac to be the same as PC in the next build.
Edited by user Friday, February 24, 2017 6:36:52 PM(UTC)
(1,258kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
So Tim any idea on why I'm limited? 2047 is the max characters I can time.
If you are on a Mac, you will need the next update. (Just corrected a few hours ago...)
If you are on a PC, I would need to know more about your steps.
I'm using a PC. VC2D/3D v9 most recent build.
Tim, let me know what other info you need. I need to get this resolved asap. Thanks
Did you try pasting text into the text box directly or did you try pasting I to the inspector when the text box is selected You can try pasting the text into a text editor like notepad++ program and then look for special characters that might be effecting pasting it in the text box Copy and paste from a basic text editor into the text box Regards Jason
I wrote the text in Word and have pasted it directly into the text and tried pasting it into the inspector. When I paste it in the text box it only pastes up to 2047 char. When I paste in to the inspector it pastes all the text but doesn't format the paragraphs. When I go into the text box to add the paragraphs it starts deleting text.
