hi all
Still using 14-day VC10 trial and really making ground...
Question about assembly workflow
Is there any performance degrading importing VC parts into an assembly as opposed to drawing within VC
I'm drawing a frame/bracket so i draw all the parts as separate VC files and then imported into an assembly VC file
A couple of other questions:
1. is there a toolbar for views? or make a custom?
2. can the base template be changed eg what VC uses as a new file
3, changing / mod linetypes in drawing sheet mode is a bit strange
heaps more to come
Andrew
Edited by user Tuesday, February 14, 2017 3:20:24 AM(UTC)
>>Is there any performance degrading importing VC parts into an assembly as opposed to drawing within VC Not that I'm aware. >>1. is there a toolbar for views? or make a custom? No however your asdfg keys are set up by default for quickly changing from right side,front,top,iso,trimetric views >>2. can the base template be changed eg what VC uses as a new file Yes, save a file as startup.dat and place in app folder. Tim
Thanks Tim
Are dim styles, line types stored in startup.dat as well? (which folder is the file in?)
When I import a VC file (solid) into the main assembly and then move it into position, it seems to leave behind the profile that made the solid
What is the best way to fill in a hole cut into a solid eg drill hole not needed?
sorry for all the questions
Andrew
Edited by user Wednesday, February 15, 2017 4:19:27 AM(UTC)
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
<<<< What is the best way to fill in a hole cut into a solid eg drill hole not needed? >>>>
I usually extrude a circle the same or slightly larger than the hole diameter, and length if needed.
Move it to the depth of the hole or object.
Add the 2 solids.
(18kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
most often you can use the "remove face" tool. make sure to select only the hole, not the solid
(140kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked rokoko for this useful post.
Thanks Rokoko, That was much easier, thanks for the information. Larry
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
... or use DeepSelect for the holes wall inside, mark it. Than only Delete needed. horst.w, GER
2 users thanked horst.w for this useful post.
