Thanks: 176 times Was thanked: 158 time(s) in 108 post(s)
I just want a Black wire, I can make a line Black, how can I make a
solid object black, really black, not gray, without rendering.
(57kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 224 times Was thanked: 175 time(s) in 106 post(s)
Originally Posted by: L. Banasky I just want a Black wire, I can make a line Black, how can I make a solid object black, really black, not gray, without rendering. Thanks, Larry
Since Velum Solid or CU, for some reason :
-->Black is dark grey
-->White is light grey...
On a Mac,
--> the second pencil on the left (lead) makes a better displayed black
--> the second pencil on the right (mercury) makes a better displayed white
(319kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked jlm for this useful post.
Thanks jlm, I'm on Windows, the thing that I don't understand is that a line can display as Black, and an object can't. Larry
The colors on solids are different then on lines. The solids black or white are alot different then lines. I always wondered why this appears this way?
(32kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
black is no problem.Deep black you can do via Color--->MORE...
Select a color that RGB values are greater than 0, 0, 0. For example 20, 20, 20.
1 user thanked digitalphaser for this useful post.
Thank you very much digitalphaser, Is there any chance of helping with the color White. Thanks, Larry
Originally Posted by: L. Banasky Thank you very much digitalphaser, Is there any chance of helping with the color White. Thanks, Larry
White is the same. If you change the
reserved Punch white 255, 255, 255 to
253,253,253 , you will get a color similar to white. The 3D object can not be absolute white. White is the reflection of the light source.
Thanks again digitalphaser, I don't understand why it works, but it does. Larry
