When I double click to open a SFX file, while the file is opening, a text file "commandline.txt" is created in the folder containing the SFX file. If I open the SFX file within Shark it doesn't create the text file.
The contents of the file is:
original command line "C:\Program -background My searches show that it's used in some gaming circumstances. Is Shark creating this or my operation system? Can I turn it off?
Anything you can tell me about it would be appreciated.
Thank you
-dale
Edited by user Thursday, February 9, 2017 2:46:33 PM(UTC)
| Reason: edit description
HP Z800 Dual Xeon 5690 3.46Ghz 64GB nVidia Quadro 6000 6GB Win pro 7-64 SharkCAD Pro v10.0.0 B1354 Shark FX v9.0.4 B1162
Hi Dale Shark is creating the "command line.txt" file. It was used to check command line arguments passed into Shark. In later builds it was disabled it. Tim
Thanks Tim. Some booleans are taking hours to complete, does "-background" effect the performance? Likewise, can I change the commandline.txt contents like the gamers and improve performance? It appears like I'm only using a small amount of memory and only one processor core, is that normal?
