HI all I'm using the new v10 on the 14-day trail so plenty of questions.. here's a possible dummy one, how do i get back to the 3d model from the 2d sheet ? Andrew
Thanks: 190 times Was thanked: 163 time(s) in 112 post(s)
Hi Andrew,
Open the Concept Explorer, and use the Layers.
Enclosed are some screenshots.
(32kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
thanks for the info
I couldn't find any information in the tips and tricks manual or help
Andrew
Edited by user Tuesday, February 7, 2017 3:22:07 AM(UTC)
HI Andrew
There should be a dialog box displayed immediately after a model to sheet indicating use of layers.
(194kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Thanks Tim There was, I just didnt read it sorry (could you have a look at my multi-line question, I'll try to explain better) Andrew
