horst.w
#1 Posted : Tuesday, January 31, 2017 12:36:35 PM(UTC)
horst.w
Hi @ all
I want to try out the funktion of MateFace.
Generally I have understood but there is an option window and I can't see any reaction of it.
The option means an Offset but I have everytime the same result.
Has anyone experiences with it?
Horst
L. Banasky
#2 Posted : Tuesday, January 31, 2017 1:07:57 PM(UTC)
L. Banasky
Was thanked: 141 time(s) in 100 post(s)
The Offset is the distance between the two faces you are mating.
Like maybe the faces of two bearings, and leaving a distance for a spacer, or a shaft.
I think the tools are mainly for assembly of multiple parts.
rokoko
#3 Posted : Tuesday, January 31, 2017 1:10:33 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
i cannot see an option window, but you can use the option key to avoid associativity of the mated objects
horst.w
#4 Posted : Tuesday, January 31, 2017 2:18:02 PM(UTC)
horst.w
Thanks for the answers!
@ Rokoko
I'm using Windows 7 Prof and the Option-Key (Mac?) is Control / Stgr but it has no effects.
Please have a look to the pictures, the starting situation and the result. With an given Offset of 30 mm I reach the same if I let it to zero.
That may be have a relation to a curios thing when I start the funktion.
Taging ON the MateFace-Symbol, also the symbol of his neighbor the Align-Function is taged ON. I can't set it to deactive without deactivation of the MateFace. Only tag ON the Align-Symbol is possible.
When using the function, with the first mouse-cklick to the first solid face, the Align-symbol is deselected.
Horst
PS: when a click to the MateFace-symbol, the mouse-flash becomes the symbol of the Align-function !
Edited by user Tuesday, January 31, 2017 2:29:13 PM(UTC)  | Reason: Not specified
Ergebnis 30 Offset.jpg (52kb) downloaded 7 time(s).
#5 Posted : Tuesday, January 31, 2017 4:32:05 PM(UTC)
FYI, this was recently corrected and will be in the next upload.
