ViaCAD 2D/3D v10 on Mac El Capitan. When I switch to Wire frame mode, following how to build a cup video, my background is white and the wire frame lines are white. How do I change the wire frame colors so I can see them against a white background? John C H Canada
Hi John
Try setting Preferences: Display: Surface: Edge color.
(148kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi Tim
the same here but at me there are no options for changing color.
All in red are blank in my preferences, the last i can see is Resolution
and the next is Pen weights.
Any idea?
Matthias
defkon attached the following image(s):
(148kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Is it possible your Object Type is set to Curve? Curves do not have these settings as an option.
(112kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Yes, this was the solution Many Thanks Matthias
