Scale when exporting STLs
In VC version 10 is new a variety of inch or feet when I export a STL
That makes trouble in my slicer (Simplify), because all values have a scale of 2,540 % ;-(
In VC version 9 there is no variety and all is well ;-)
Properties are millimeters for the units.
regards
Horst
Edited by user Sunday, January 15, 2017 7:33:10 AM(UTC)
(83kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
An other point:
In properties is UNchecked "Enable Tool Tips",
nevertheless the ToolTips are coming up when starting the program.
Edited by user Sunday, January 15, 2017 7:38:18 AM(UTC)
(68kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
no problem here on a mac with tool tips. tool tips mean the readout when hover over a tool icon
Edited by user Sunday, January 15, 2017 10:53:32 AM(UTC)
aaah, thanks with the ToolTips. Thats now cleared >>> Uncheck the box in the first window that appears. H.
Originally Posted by: Guest ... >>> Uncheck the box in the first window that appears.
I'm sorry but it doesn't works!
(67kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
When importing a STL-file and reparing with the PowerPack, the following re-export offers only mm and cm as scale-dimension.
Thats ergo the real contrast to the origin export out of ViaCAD 10.
Greetings
Horst
Edited by user Friday, January 27, 2017 7:58:27 AM(UTC)
(48kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
>> offers only mm and cm as scale-dimension. Hi Horst Thanks for the heads up. The menu is not shown to its full length on PC requiring using the keyboard to change settings. I just updated this for the next build of 1325. Tim
That's why "!!! Thanks!
I had not the idea to scroll up and down ;-(
And the other problem with the position of 2-color-objects (
http://forum.punchcad.co...sts&t=8327#post31720 )
seams also solved!
I tried it out. I had created the objects myself with ViaCAD 10 and couldn't export with the mm-scale, therefore the scale was inch. I don't know if there is a relation but the import of this objects had the problem with the position.
Now I have imported these STL-inch-objects once more to ViaCAD 10 and re-exported them in mm-scale. The import to simplify is ok, all objects are on their right places. That must have a reason - and I had done no changes to the settings of ViaCAD and Simplify.
