horst.w
#1 Posted : Tuesday, January 24, 2017 3:50:45 PM(UTC)
horst.w
I have drawn a rectangular polygone between 2 construction lines on the workplane in top-view.
After that I modified the messures of the X- and Y- dimensions in Width- and Hight-window of the data-entry.
But when I change the values the polygone is jumping away to a different position without any relationship to the two guidelines.
What is going wrong there?
ViaCAD V10
Horst
p.s. rounded rectangle the same.
Edited by user Tuesday, January 24, 2017 4:10:44 PM(UTC)  | Reason: Not specified
Modify Polygone.jpg (68kb) downloaded 8 time(s).
Modify Polygone-2.jpg (56kb) downloaded 9 time(s).
L. Banasky
#2 Posted : Tuesday, January 24, 2017 5:24:07 PM(UTC)
L. Banasky
You have negative numbers for one size, and positive numbers for
the other one.
#3 Posted : Wednesday, January 25, 2017 2:11:43 AM(UTC)
... yes, but thats not my typing, thats automatical and not to avoid. I believe there is a crossing of values of coordinate datas. Very cryptic.
The effect is also coming up when using an empty workplan and I put the startpoint to origin. The drawn polygone is jumping far away.
Horst
sorry, not loged in
Edited by user Wednesday, January 25, 2017 2:18:16 AM(UTC)  | Reason: Not specified
horst.w
#4 Posted : Wednesday, January 25, 2017 3:22:22 AM(UTC)
horst.w
The negativ values of Width and Hight are depending to the startpoint of drawing, pull out to left or to right side, going up or down. I aspect only the true dimensions of the polygone in the Width and Hight-windows and not combinated with the direction of the drawing. I believe that is the point because when typing in the keyboard new values, I don't know on what way I had drawn the polygone some time before.
Version ViaCad 9 had never shown this effects.
