horst.w
#1 Posted : Saturday, January 14, 2017 12:00:09 PM(UTC)
horst.w
In VC version 10 is new a variety of inch or feet when I export a STL
That makes trouble in my slicer (Simplify), because all values have a scale of 2,540 % ;-(
In VC version 9 there is no variety and all is well ;-)
Properties are millimeters for the units.
regards
Horst
Edited by user Sunday, January 15, 2017 7:33:10 AM(UTC)  | Reason: Not specified
V9-NoVariety .jpg (83kb) downloaded 10 time(s).
horst.w
#2 Posted : Sunday, January 15, 2017 7:36:46 AM(UTC)
horst.w
An other point:
In properties is UNchecked "Enable Tool Tips",
nevertheless the ToolTips are coming up when starting the program.
Edited by user Sunday, January 15, 2017 7:38:18 AM(UTC)  | Reason: Not specified
rokoko
#3 Posted : Sunday, January 15, 2017 10:45:14 AM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
no problem here on a mac with tool tips. tool tips mean the readout when hover over a tool icon
Edited by user Sunday, January 15, 2017 10:53:32 AM(UTC)  | Reason: Not specified
#4 Posted : Sunday, January 15, 2017 3:37:11 PM(UTC)
aaah, thanks with the ToolTips. Thats now cleared >>> Uncheck the box in the first window that appears.
H.
horst.w
#5 Posted : Monday, January 16, 2017 4:46:35 PM(UTC)
horst.w
Originally Posted by: Guest Go to Quoted Post
... >>> Uncheck the box in the first window that appears.
I'm sorry but it doesn't works!
horst.w
#6 Posted : Friday, January 27, 2017 7:55:44 AM(UTC)
horst.w
When importing a STL-file and reparing with the PowerPack, the following re-export offers only mm and cm as scale-dimension.
Thats ergo the real contrast to the origin export out of ViaCAD 10.
Greetings
Horst
Edited by user Friday, January 27, 2017 7:58:27 AM(UTC)  | Reason: Not specified
#7 Posted : Friday, January 27, 2017 12:53:56 PM(UTC)
Hi Horst
Thanks for the heads up. The menu is not shown to its full length on PC requiring using the keyboard to change settings. I just updated this for the next build of 1325.
#8 Posted : Friday, January 27, 2017 5:21:31 PM(UTC)
That's why "!!! Thanks!
I had not the idea to scroll up and down ;-(
And the other problem with the position of 2-color-objects ( http://forum.punchcad.co...sts&t=8327#post31720 )
seams also solved!
I tried it out. I had created the objects myself with ViaCAD 10 and couldn't export with the mm-scale, therefore the scale was inch. I don't know if there is a relation but the import of this objects had the problem with the position.
Now I have imported these STL-inch-objects once more to ViaCAD 10 and re-exported them in mm-scale. The import to simplify is ok, all objects are on their right places. That must have a reason - and I had done no changes to the settings of ViaCAD and Simplify.
