#1 Posted : Friday, January 06, 2017 5:58:32 PM(UTC)
I have been using Viacad since V8, I import various stp files. I bought a new v10 edition with the power pack and have installed this on my new MacBook Pro computer. Unfortunately, none of my files can be imported, I receive an error message:- "The import/export failed with error:File save error. Would you like to see the detailed log file
I have pasted the log file for you.
For ref, all of these files open in V8 and V9 of which is still installed on another machine. Also, in your sample files, even your own stp files cannot be opened.
Please help
Andy
Translator Name : Spatial InterOp Connect ( Version : 2017 1.0.0)
System Name : Darwin
Machine Name : MBP-TCL-AHs-MacBook-Pro-4.local
User Name : tcl
Source System : STEP
Destination System : ACIS
Input File : /Users/tcl/Desktop/ax100-11-002_Q_13DEC2016.stp
Output File : /var/tmp/tmp.0.tY8T4d_SPAIop_1_Doc.sab
Start Time : Sat Jan 7 08:53:22 2017
Message : === Translation Options ===
Message : TranslateSheetBodies : 1
Message : TranslateLayersAndFilters : 1
Message : TranslateAllClass2SheetsInSingleBody : 1
Message : TranslateAttributes : 1
Message : TranslateFreeCurves : 1
Message : Healing : 1
Message : TranslateFreeSurfaces : 1
Message : EnableWideCharacter : 0
Message : ===========================
-------------------------Source File Header Information-------------------------
Modification Date : 2016-12-13T
File Name : AX100-11-002_SUMP_V4
Author : 'AC'
Organization : ''
Source System : PRO/ENGINEER BY PARAMETRIC TECHNOLOGY CORPORATION, 2010480 PRO/ENGINEER BY PARAMETRIC TECHNOLOGY CORPORATION, 2010480
Version : AP203
Authorization :
File Description : ''
Implementation Level : 2;1
File Schema Name : 'CONFIG_CONTROL_DESIGN'
Document Type : Part
Units : MILLIMETER
Format Type : STEP
Source Document Preprocessing Result : Success
Target Document Preprocessing Result : Success
Start BRep
BRep Source Representation Preprocessing Result : Success
BRep Source Representation Postprocessing Result : Success
BRep Target Representation Postprocessing Result : Success
End BRep
------------------------Representation Conversion Summary-----------------------
No. of Acorn Bodies : 0
No. of Mixed Bodies : 0
No. of Solid Bodies : 1
No. of Wire Bodies : 0
No. of Free Surfaces : 0
No. of Free Curves : 0
No. of Sheet Bodies : 0
No. of Free Points : 0
BRep Conversion Result : Success
Start DocumentFeature
DocumentFeature Source Representation Preprocessing Result : Success
DocumentFeature Source Representation Postprocessing Result : Success
DocumentFeature Target Representation Postprocessing Result : Success
End DocumentFeature
No. of Selection Sets : 0
No. of Working Coordinate Systems : 0
No. of Associative Groups : 0
No. of Layer Filters : 0
DocumentFeature Conversion Result : No Entity to Translate
Start Assembly
Assembly Source Representation Preprocessing Result : Success
Assembly Source Representation Postprocessing Result : Success
Assembly Target Representation Postprocessing Result : Success
End Assembly
Assembly Conversion Result : No Entity to Translate
Target Document Postprocessing Result : Success
---------------------------Document Conversion Summary--------------------------
No. of Items of DocumentFeature Representation : 0
No. of Items of BRep Representation : 1
Message : Setting save mode for ACIS file based on the file extension
Output File "/var/tmp/tmp.0.tY8T4d_SPAIop_1_Doc.sab" Writing has Failed with code 16777217
Error : Target document not saved.
Finish Time : Sat Jan 7 08:53:27 2017
Translation Result : File Save Error
#2 Posted : Saturday, January 07, 2017 12:20:59 PM(UTC)
Was thanked: 234 time(s) in 203 post(s)
Hi Andy
Is this a copy of ViaCAD from the Mac App Store?
Vice President Software Development
A6M
#3 Posted : Saturday, January 07, 2017 2:24:23 PM(UTC)
A6M
Yes bought from Mac store Dec 3rd 2016
#4 Posted : Wednesday, March 08, 2017 5:53:15 AM(UTC)
Hi all.
Got the same problem.
Bought ViaCad from Appstore, and cant't import STEP Files.
SAT and others (AI, EPS) works fine for importing.
Thank you for helping.
Best Regards.
Lukas
#5 Posted : Wednesday, March 08, 2017 12:08:11 PM(UTC)
Hi Lukas
Have you downloaded the Mac App Store update for ViaCAD? Can you provide your build number from the splash screen?
#6 Posted : Thursday, March 09, 2017 1:55:02 AM(UTC)
Dear Tim
I work with. 10.0.1
Build 1329
#7 Posted : Thursday, March 09, 2017 10:48:44 AM(UTC)
>>Build 1329
Downloading app store build today to check....
