ceria
#1 Posted : Thursday, December 29, 2016 9:08:15 AM(UTC)
ceria
With viacad version 10 it appears that extruding a solid with any draft angle entered results in a acis error "rigid sweep with draft". If I try the same task in viacad 7 it works fine. I am simply trying to extrude a 20x20 cube 10mm with a draft angle of 4. Has anyone else have had this problem.
Edited by user Thursday, December 29, 2016 9:09:14 AM(UTC)  | Reason: Not specified
#2 Posted : Thursday, December 29, 2016 2:20:37 PM(UTC)
This is now fixed in the next V10 build. Thank you for the heads up!
Until the next build, use the Vector option for extrude
Edited by user Friday, December 30, 2016 12:58:39 PM(UTC)  | Reason: Not specified
