a good idea, but still a second imprint is remaining inside the goblet
Originally Posted by: rokoko a good idea, but still a second imprint is remaining inside the goblet
I revisited the ACIS documentation regarding projections and imprints but did not find an option for first imprint. Kinda like our hole that has through, first blind, etc.
I'll need to send them an email.
Thanks: 8 times Was thanked: 77 time(s) in 39 post(s)
Rokoko,
No imprint in VicaCAD V10 on the inside of the goblet. Here is another screenshot:
Mitch
mitchb attached the following image(s):
(81kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
funny - in my drawing i can see it
build 1317 macos 10.9
Edited by user Thursday, December 15, 2016 11:49:13 PM(UTC)
(139kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
In your display options, you are using "Phong with edges". Change it to just Phong. Mitch
You guys are awesome ! Thanks so much for the help and special thanks to Tim & video he made. Here is what I came up with.
Jester3775 attached the following image(s):
(140kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Jesse ViaCAD Pro 10 Powerpack macOS Sierra 10.12.2
Not totally sure why but I couldn't seem to upload file as a .vcp ? I am thinking the file is too big ? Again thanks guys !
Hi Guys, This is probably a dumb question but... how do I now delete the text off goblet ? I added blends to the face surfaces & the blending into the cup. I try to select text and cut, I try to select text and hit delete key on keyboard but to no avail. Most of the time I try these and as many variations I can think of & ViaCAD Pro 10 freezes up ! Did I wreck it ?? Thanks, Jesse
Well, did I wear out my welcome here or did I actually throw you folks for a loop !? Still hoping someone could help me remove the text from goblet. Thanks, Jesse
hi, choose deep select tool and select the letter "R". hit delete key
(78kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Hi, Thanks for getting back to me rokoko. I tried like you said and it does not work, in fact ViaCad Pro 10 locks up upon me selecting and hitting delete. My drawing looks a little different than the one you are showing. I extruded the letters and curved the edges like Tim showed me. Maybe this requires something different ? Thanks, Jesse
Rayne Delete.pdf
(222kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
If you have an example file with steps to repeat for any crash or lock up please send to link below and we will look into.
http://www.punchcadlabs.com/page10/page10.php Tim
Hi Tim, I tried and it said file is too big, here is a screen shot.
Punch cad.pdf
(216kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
Your letters are pulled out to 3-dimensional volumebodies. Then DeepSelect means only the surface in front and not the whole object
Hi Horst, Yes you are correct it seems. I thought I have explained the 3-dimensional thing but I think I failed ! It seems like I can also individually choose the radius ? parts I added to face and where it joins cup. However whenever I make any of these choices the software locks up. I am trying to remove name completely to add a different one if it helps to know that. I feel like I can understand why it can't just delete part of the letters but I can't seem to choose all of a letter to delete. Hope that makes sense. I am trying to upload the file for Tim because I think he is also worried about the software "locking up" and I end up having to do a force quit on my Mac to restart the software. The file is too big apparently so I am hoping he tells me what to do at this point to share. It would figure I am just getting into this stuff and I am already wrecking it ! Thanks, Jesse
Hi Guys, not really sure what proper etiquette is but I was still hoping for some help with removing text and was hoping to hear from Tim again...
Hi Jesse
Can you zip the file and send using the bug reporter link below? The link below has a larger attachment size then the forum attachments.
Hi Tim, I tried again and it did not work. The file is 7.8 MB, when I zip it 7.6 MB. The link again said it only accepts 2 MB. What can I do ? Thanks, Jesse
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
Please just take this as a suggestion, I have done it many times myself. Start over as a new file. I don't see how the file should be 7.8 MB. Maybe too many different operations and edits have caused problems. Larry
Hi Banasky, Thanks for the advice. I think you mean delete the one I am trying to work with and make a whole new one ? I don't have a clue how big a file I should have, 7.8 MB seems small to me in general but I have no clue I guess on drawing files. Granted this is a relatively easy drawing to make again but.... I hate to think this might happen again on a more involved drawing ? And it still doesn't seem to explain why the new software I upgraded to is crashing.
