Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
Hello Tim,
Strange behavior, right?
Thank you
Edited by user Wednesday, December 21, 2016 7:58:43 AM(UTC)
surface.sfx
(363kb) downloaded 14 time(s). Antoine attached the following image(s):
(108kb) downloaded 23 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi Antoine,
tested cover surface with your bezier curves in ViaCad 10 Beta ( 1317)
No problems, all surfaces are the same.
Edited by user Wednesday, December 21, 2016 9:20:51 AM(UTC)
defkon attached the following image(s):
(64kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
Was thanked: 521 time(s) in 358 post(s)
Not intuitive, but I believe correct. The surface goes through the guide point with the given edges.
The Cover with Guide solves a set of equations/constraints to produce and internally smooth G2 surface. There may be more than one answer to the set of equations obvious to the designer but less obvious to the equation solving process:)
Currently I internally default some of these settings that control the outcome. I may need to look at exposing those additional settings to the designer.
Something else you can do to control the take off direction is to add extruded surfaces to the boundary curve and use the Tangent Cover with Guides tool as in attached example file. This method adds more constraints to get the shape you are looking for.
Edited by user Wednesday, December 21, 2016 1:44:46 PM(UTC)
tcg.sfx
(124kb) downloaded 13 time(s). Tim Olson attached the following image(s):
(99kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Thank you very much Tim. Joyeux Noël! :) Antoine
