la mouche
#1 Posted : Wednesday, August 14, 2013 1:45:32 AM(UTC)
la mouche
Hello Tim and co,
I repeat an action that still has the same bug for many years.
Indeed, SharkFX is not able to interpret correctly MTS mode: model to sheet
There are many errors in the projection in 2D engineering drawings and translation of hidden lines, visible, etc..
Currently it is so unusable, I have to use another program for my engineering plans with an export model built with SharkFX. This is absurd and I would love it to be repaired.
http://www.screencast.com/t/PBNIS3NBx
Thank you in advance and long live Shark!
Antoine
cube and mts.sfx (1,682kb) downloaded 7 time(s).
Jean-Francois Jacques
#2 Posted : Wednesday, August 14, 2013 9:06:45 AM(UTC)
Canada
Same issue with V9
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#3 Posted : Wednesday, August 14, 2013 9:10:56 AM(UTC)
Canada
Same issue!
#4 Posted : Thursday, August 15, 2013 4:42:15 PM(UTC)
Will look into in the 1084 build coming up this weekend.
la mouche
#5 Posted : Monday, August 26, 2013 1:34:58 PM(UTC)
la mouche
you have some new info?
#6 Posted : Monday, August 26, 2013 3:54:06 PM(UTC)
Was thanked: 173 time(s) in 105 post(s)
Hi Antoine,
I used Beta V9 today to do MTS.
Good news : some of the "historical" bugs have been solved !
And it is faster...
Promising.
#7 Posted : Monday, August 26, 2013 8:29:25 PM(UTC)
The SDK does not handle occluded dashed/visible line segments very well. I'm gradually rewriting that portion.
