theo52
#1 Posted : Friday, December 16, 2016 9:33:26 AM(UTC)
theo52
Netherlands
I work with ViaCad 10 pro and in the past I could place an object or whatever above the grid (with the Z position).
Now always the grid is above my object, how comes?
Anyone kwows?
Thanks in advance
theo52 attached the following image(s):
grid problem.jpg (20kb) downloaded 14 time(s).
#2 Posted : Friday, December 16, 2016 9:58:36 AM(UTC)
Originally Posted by: theo52 Go to Quoted Post
Anyone kwows?
Thanks in advance
Hello
The grid locates on the origin of the workplane, so if your workplane is above the object that is where the grid will display.
Use the workplane --> set origin
theo52
#3 Posted : Friday, December 16, 2016 10:17:52 AM(UTC)
theo52
Netherlands
Thanks Jdi000
No result, with pressing on "set origin" nothing change.
I also re-installed Viacad, also no result
Thanks anyway!
Kind regard, Theo
#4 Posted : Friday, December 16, 2016 3:02:43 PM(UTC)
Theo
Can you post that sample file, and list the steps you used to turn the grid on and create the geometry.
theo52
#5 Posted : Saturday, December 17, 2016 12:23:59 AM(UTC)
theo52
Netherlands
Hi Jason,
I can post a sample file, I can take all files, no matter which one, all the same problem.
I notice that if you open my file it will be opened in your ViaCad program and perhaps there is no problem at yours.
So I will attach 1 files and a few images the way it looks on my computer.
Thanks, Theo
bold.vcp (1,136kb) downloaded 13 time(s).
theo52
#6 Posted : Saturday, December 17, 2016 12:30:49 AM(UTC)
theo52
Netherlands
In the previous post you can see with picture no.4 that the bold is created above the grid but the top-view shows also grid over it..
Kind regards,
Theo
#7 Posted : Sunday, December 18, 2016 12:42:50 AM(UTC)
Can you check that your View : Shade Options : Zuffer Curves is enabled?
theo52
#8 Posted : Sunday, December 18, 2016 2:34:35 AM(UTC)
theo52
Netherlands
YESSSSS!
Thanks Tim, that was the problem!
Due to the fact of exploring the program I changed to much at 1 time I guess..?
Thanks!
Kind regards, Theo
Guest (5)
