KSimmons
#1 Posted : Monday, December 12, 2016 2:09:35 PM(UTC)
KSimmons
Hi there, I was trying different export files to which one would work in AC3D. So I could use the X-Plane plugin for AC3D to create an X-Plane .obj8 file to use in building scenery objects. Currently I have X-Plane 10.51 and X-Plane 11 Beta2 installed. Different programs can have their own .obj file such as X-Plane which are not suppor to be compatible with Wavefront Obj file. So I was surprised and puzzled that when I exported a test object such as a box, torus, cone as a Wavefront .obj file to a document folder (anywhere) the objected saved as an "X-Plane 3D Object". Why. See http://developer.x-plane.com/ under "Documentation. Have attached a screenshot of the folder with the wavefront .obj files.
KSimmons attached the following image(s):
Shark LT v9 Wavefront export file.png (34kb) downloaded 12 time(s).
#2 Posted : Monday, December 12, 2016 2:33:35 PM(UTC)
Hello
The files export out as .obj files. If you have a program associated to open these then it will display as that type of file. If you display the file extension it should be .obj I would guess that the operating system is just associating the .obj with X-Plane 3D object.
In Win 10 i have the app called 3d builder installed and it associated the .obj to that program and uses its icon image for the file.
KSimmons
#3 Posted : Monday, December 12, 2016 3:47:10 PM(UTC)
KSimmons
OK, Thanks.
