Old Dude
#1 Posted : Thursday, December 8, 2016 11:42:52 PM(UTC)
Old Dude
I have created two 2D objects. On is a circle and the other is sort of a square. The square exists of a combination of arcs connected by radial lines and fillet connection points (see pic). The objects are on a different Z plane approx 10mm apart. I want to turn these separate 2D objects into single 3D object that flows from a circular shape to the square. I am yet to figure out how to tackle this. Any suggestions welcome.
Old Dude attached the following image(s):
Shark LT challenge.jpg (61kb) downloaded 17 time(s).
24c
#2 Posted : Friday, December 9, 2016 12:55:17 AM(UTC)
24c
Was thanked: 69 time(s) in 51 post(s)
Hi Old Dude,
I thought Skin Solid would do this? It's here on the menu.
Mike
Skin Solid.png (57kb) downloaded 10 time(s).
macOS Tahoe - v16 beta
Old Dude
#3 Posted : Friday, December 9, 2016 5:46:44 AM(UTC)
Old Dude
Hi Mike,
I had tried this option to no avail, i thought, I was in wireframe mode and saw a single line appear between the object. I expected a wire mesh. When I switched to shaded view the magic suddenly appeared to have happend. Thanks a million for your help!
Old dude
