Solid Modeling
Simple way to convert STL to solid
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
I don't have Powerpack, but ViaCad 2D/3D v8 (v9 as well, but the latest release is unworkable) and I stupidly used STL's in my design. It was the only way to get a bit of speed with ViaCad, as with the solids it took about 5-10 minutes when you moved them. Anyway, I read a few months ago, the standard version of our software has a function to convert simple STL objects to solids. It was not a dedicated function like Powerpack had, but something already built in that does the trick as well. But I can't remember it. Who does?
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Import the STL file.
Select All.
Edit- Change Object Type-Choose Solid
(49kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
Oh, I thought and remembered wrong that that didn't work. But I just tried it and it does work indeed. Very slow, but it works... Thanks for the reminder!
When I have converted the Mesh to a solid, I would like to smoothen it and remove the triangles. I remember seeing this in a video of Tim, but don't know the video anymore and can't remember how this goes. Is this possible with ViaCad 2D/3D or Pro and power pack?
It takes Power Pack Pro convert-to-nurbs, but even that doesn't like triangles much. Preprocessing to quads within PPP isn't always satisfying either. Retopology is something that needs attention.
ViaCAD/Shark will stitch facets with no errors up to around 4000. Each facet will create one face in the resultant solid.
PowerPack Pro will:
Stitch larger number of facets --Licenses additional technology that supports stitching large number of facets Subdivision to NURB —Converts mostly quads NURBs —Produces optimized NURBS (ex 2M quads converted into 832 nurb faces) —G2 (smooth) between patches —Unlike T-Splines, supported on MAC —Video Link General Mesh to Analytic Solid —Segments a mesh into analytic shapes and restitches into solid —Helps preserve holes, circles, arcs, and splines --Video Link TimEdited by user Tuesday, December 6, 2016 5:17:52 PM(UTC)
Originally Posted by: Tim Olson >>Is this possible with ViaCad 2D/3D or Pro and power pack?
PowerPack Pro will:
General Mesh to Analytic Solid —Segments a mesh into analytic shapes and restitches into solid —Helps preserve holes, circles, arcs, and splines --Video Link Tim Hi Tim,
in my ViaCAD 10 PRO (Build 1308) with PowerPack I miss some functions: (Mesh to Analytic)
Markus
(1,360kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
ViaCAD 10 PRO + PowerPack / MAC OSX 10.12 Sierra
There has been confusion between PowerPack and PowerPack Pro.
I think what you have is ViaCad 10 Pro with PowerPack.
The additional Mesh tools are only included with PowerPack Pro.
(79kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
>>The additional Mesh tools are only included with PowerPack Pro. The mesh to solid tools license a 3rd party library which is available in PowerPack Pro. Tim
Solid Modeling
