markm
#1 Posted : Friday, November 25, 2016 11:47:55 AM(UTC)
markm
Program will not open. I tried reinstalling and still will not open. I am ctrl+click etc, and I've used this for two years now. I wanted to price the upgrade but I cannot access the serial number. Not even my files!
Any ideas?
#2 Posted : Friday, November 25, 2016 1:21:25 PM(UTC)
Rank:: Senior Member
Does it display an error dialog? If not, does it display a message in Console?
markm
#3 Posted : Friday, November 25, 2016 1:38:22 PM(UTC)
markm
no error. the icon bounces for a few (2 minutes on the first try, seconds on subsequent attempts) and... nothing. Doesn't showup in the resource monitor. I've used it on this machine for couple yrs.? The machine was off for a few months and now its back up and running. VCAD is not. I actually got the email about V10 and decided to look.
The only thing that's changed on this machine is the usual updates from apple. It's running "yosemite 10.10.5" I'm not a regular console user so I have no idea if anything is reported.
Tx
#4 Posted : Friday, November 25, 2016 2:17:58 PM(UTC)
I'm not sure offhand. You might want to contact tech support and request a current installer to reinstall the product.
If you are rushing to use the black friday promo, you will find the serial number in the the VCPRegInfo.ini or VC3RegInfo.ini file found with a search.
markm
#5 Posted : Friday, November 25, 2016 3:02:12 PM(UTC)
markm
Hey thanks for your help. I was not able to find anything except a support ticket opening under the new orders section. The support section goes to a knowledge base... not especially useful here. Useless actually. No mac-specific support etc..
Example, I don't have any .ini files on this mac. Maybe that's a windows type?
#6 Posted : Friday, November 25, 2016 3:29:04 PM(UTC)
Use the link below, don't worry about the product name. However, they are about to leave for the weekend.
http://support.encore.co...frm.aspx?product_id=2820
It is the same text file on Mac and PC.
For ViaCAD Pro the file location is:
/Users/<username>/Library/Application Support/com.encore.viacadprov9esd/VCPRegInfo.ini
For ViaCAD 2D3D the file location is:
/Users/<username>/Library/Application Support/com.encore.viacad3dv9esd/VC3RegInfo.ini
markm
#7 Posted : Friday, November 25, 2016 3:45:14 PM(UTC)
markm
interesting. I dont have a library folder after the user (user/library/...) only under macintoshHD/library/application support/...
In this folder there is no com.encore folder.
rokoko
#8 Posted : Friday, November 25, 2016 11:49:54 PM(UTC)
rokoko
usually on mac the user library folder is hidden. -> go to finder and use "go to" menu with alt key. you will see the library in the pull down menu.
