matteopaluffi
#1 Posted : Tuesday, November 15, 2016 12:53:11 AM(UTC)
matteopaluffi
Hello
Is possible in viacad or shark create a thread hole but with 2d symbol of thread (the arc symbol rapresentation).
Thank you
Bye
matteopaluffi
#2 Posted : Monday, November 21, 2016 12:28:26 PM(UTC)
matteopaluffi
I have found a solution :-) I created a scalable 2d symbol with a drill diameter reference. Solution simple and fast.
L. Banasky
#3 Posted : Monday, November 21, 2016 1:57:58 PM(UTC)
L. Banasky
Shark has had symbols for a long time. I have used Shark for a long time.
I have never figured out how to use the threaded hole symbols.
Try using a threaded hole in Model-to-Sheet, drag it into your view and
the dashed lines turn into solid lines, and can not be edited or even selected.
Please share with us your method of placing threaded holes in a Model-to-Sheet
drawing.
Your method will be greatly appreciated.
Tapped Holes.jpg (101kb) downloaded 11 time(s).
Antoine
#4 Posted : Wednesday, November 23, 2016 8:06:17 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
+1 Matteo :)
murray
#5 Posted : Wednesday, November 23, 2016 5:57:02 PM(UTC)
murray
They drag and drop from CE, I can select and edit line type, weight, scale, although these are all global settings, not individual elements, and they display as they're represented in the library. Win 7 & 8.
L. Banasky
#6 Posted : Friday, November 25, 2016 5:21:19 AM(UTC)
L. Banasky
Thanks Murray,
I found out that you can 'Right-Click' and 'Ungroup' after drag and drop into
Model-to-Sheet views, then the symbol can be edited.
rokoko
#7 Posted : Friday, November 25, 2016 7:31:19 AM(UTC)
rokoko
with deep select tool you can edit objects inside a group without ungrouping
GARLIC on 11/25/2016(UTC)
L. Banasky
#8 Posted : Friday, November 25, 2016 10:59:52 AM(UTC)
L. Banasky
Thanks Rokoko,
In the Model-to-Sheet view 'Deep Select' seems to select the whole symbol.
I only want to select the outer circle, and change back to a 'Dashed' line.
After 'Deep Select' all the lines change to 'Dashed'.
Deep Select.jpg (83kb) downloaded 5 time(s).
